Segmenters
Ok segmenters I have looked at this pen many times in the past and have yet to figure out how it was made. I can make a guess in that it was done in strips but this is the only photo I could find and it is hard to see even if I magnify it. This is from the old site and the turner does not come here any more. From 2015. I have a few ideas I would like to try with that design but right now it eludes me. My attempt would probably with the use of a router but that would be a feat. The other thing I thought of doing a window and building the design within that window. Open for ideas. Maybe it is more simple than my simple mind is making it out to be.
https://www.penturners.org/media/another-segmented-pen.28628/
Hi John I'd imagine it's done in strips as you've said. I found this example on FB that looks similar in construction.
I would think it's done with strips. Can't tell from the photo though. Could be done with blocks, but either way, seams would be evident.
That is my point I can not see seams. I wish I could have blown it up or had a closer photo. The thing that stands out is that is a slimline pen and the design is well seen around a slimline pen. Now that is not easy. The OP did not do a thread on the pen. He just put it in his gallery. I checked his messages and there was no mention of it. I have one other place to look through and maybe can get a better picture. Will check.
He also made this pen. He would have been a great segmenter here.
https://www.penturners.org/media/wenge-w-segmented-cross.28627/
And this one
https://www.penturners.org/media/bow-riser-pen.28624/
That one I believe I can see the strip at the center of the cross.
That's interesting, John....especially on a Slimline.
The pattern in the top photograph has 7 'strips' lengthwise but also 7 'strips' in height...and the pattern does not continue all around the barrel.
One other possibility is a CNC cutting and segmenting. There were CNC cuts way before that. With black, lines would not be noticeable and micro spaces also would not be noticeable.
