Longleaf Pine cone pen
Gary Beasley
Marietta, Ga. USA
Start with cones from a longleaf pine. Make sure they are dry. They have pretty good sized cones with thick cores. There are a few other species that can be used, this one was very common in the south before they were nearly wiped out from over logging.
Then a belt sander to remove most of the leftover tab stumps.
Soak some thin CA into the ends once they are trimmed to useable length. Drill from the small end so you can center the bit accurately.
Prior to gluing the tubes in soak the inside with thin CA to reinforce the soft wood and ensure adhesion.
The wood is soft so turn with a sharp tool using a light touch
Makes a very unusual figured pen.
These were fairly popular 12-15 years ago. It's nice to see they are still being made.
You did a nice job! I've always saturated the hole with the thinnest CA I could so it semi stabilizes the core. Then as you turn it, give it a thin layer of (now ultra thin) CA to help hold it all together. Their softness makes it easy to make them out of round so the CA helps.
I have tried the soaking before, it makes the surface quite hard to turn. The interior soak helps hold it together too. I havent had any problems with out of roundness.
