Well I probably over complicated this one, but the end results were worth it. I built actually two jigs to make the blank, one for my drill press and one for my bandsaw. First I take a square blank, counter sink each end, to accommodate a dead and live center, also on each end I drill a hole for some screws. From there I mount it between center and just turn it round. Then I screw two hexagonal wheels on each end and that assembly drops into a carriage that perfectly fits the hexagons. That is then mounted on my drill press with the round blank being perfectly centered with the drill bit. Then just drill, rotate the blank and drill all the way around. You can drill 6 holes halfway or 3 all the way through. I had my best luck going halfway through. I tried first with a jobber bit, but it wanted to wander to much. I bought a stubby brad point and it works well. After all the holes are drilled it goes into the saw jig where there is a brass pin that is centered in the "V", where the blank sits . Mount the blank onto the pin, cut most of the way through Remove it and glue in your infill. Put it back on the lathe and turn down the infill. Using the next hole remount on saw jig and repeat. The angle of the blank is not adjustable. I cut all my knots at 55° so for me, different angles aren't needed.
