Refills drying out
keithbyrd
Mount Wolf, PA
I have a customer who has bought about 20 pens from me over the years all exotic animals that he has hunted and I made pens out of the antlers and horns. The pens normally set in a collector case and he occasionally gets one out to sign a contract or something unique but they get very little use. He put new refills in all of them about a year ago but they have all dried up. So my question is what is the shelf life of Schmidt 5888 rollerball refills?
Have any of you had this problem and is there a way to fix it?
Thanks for your advice and insight!
I cannot speak the the technical shelf life per the manufacturer specs.
Are the pens laying on their sides when they are stored? My experience is that when ink cartridges are stored with the tip down they do not dry up as quickly. An occasional one will dry up or leak but generally they last quite a while. The cartridges I have had laying on their sides do dry out faster. Maybe advise him to store the pens different if possible since he doesn't use them consistently.
This actually could be a very good topic and not just for that particular refill. One of those topics that probably would need contacting manufacturers. I hope maybe some has done some study on this and report their findings. Maybe there is no real answer or maybe it is just different type of inks. Think about it. Pen kits are stored on shelves and in boxes and not stood up wise as mentioned and does this lead to less life of refill. It is not like you can shake the refill like a paint can. Now to counteract this, most refills come with a seal on the tip so that can be a point about storing especially rollerballs. I hope we can get some valuable info here and maybe the vendors can contact their sources to help make this one of those library threads.
This just happened to me yesterday. I had to write a quick note. All pens in my desk stand are vertical, pen tip down. None of the 5888 or G2 pens with refills less than a year old would write. A slimline with the kit 10+ year old refill wrote without a hiccup. P900 ballpoints are similar to 5888 in 'not writing' abilities.
New refill has a little bead of glue or something on the tip. For the other end of a new refill, a small piece of masking tape should seal it.
An advantage of ballpoints: can be fitted with pressurized ink refills (fisher) 100 yrs shelf life. Dunno if theres a rollerball like that..
It also depends where he gets his refills from, I find the generic refills supplied with kits and the cheap replacements obtained probably from China all contain a small fraction of ink compared with in my case genuine Parker refills.
Mind you I had a few boxes of genuine Montblonc rollerball refills that all dried out in their boxes.
I also found Monteverde refills to be quite reliable.
most are standing up with the cap at the top so tip up. Displaying them with the cap down would look somewhat out of place!
These are all Schmidt 5888 supplied by me!
I haven't noticed that seal on rollerball refills. The only thing I am aware of is the cap. Apparently once that comes off the tryout clock starts ticking!
I went to one of our main suppliers and was told it would be best to contact the manufacturer!
IMO, this is the reason. I would think that if the tip is up, depending on the length of time it is in that position would allow the ink and the air space would eventually exchange places. They haven't "dried up". It just takes a while for the positional change between the ink and the air space to happen.
Perhaps a better idea would be to build this customer a horizontal storage display. Or perhaps get a little fancy and build a rolodex type display that would store them flat.
Either that or store them with the cap posted on the back end and the tips down. This would probably create it's own problem of leakage.
I bought a bunch of refills on Amazon. I stored them in a horizontal position. I just used some kits that I have had for a few years. The ink in some was dried up. I thought, no problem I have refills. About half of the refills were dried up also. They had end caps, too. I'm about to order a few refills, but this time I'll be more selective and try to buy better quality.
I have found you can revive a "dried out" cartridge by standing them on end in a cup of boiling hot water for five or ten minute. Seems the ink is not so much dry but oozed away from the tip after spending a few years laying on its side. The heat melts the ink enough to flow back into place.
