Coffee Tamper Handles
woodwzrd
Baraboo WI
One of my interns approached me a few weeks back and asked if I would be able to make custom hybrid handles for two coffee tamper bases his Grandfather made for him. One base is solid brass and the other is stainless steel. He wanted blue and silver resin and the wood was of my choice. I used maple burl and JB Royal epoxy. He was very pleased with the outcome.
The handles look great!
I would suggest trying to buff out those tool marks on the metal to really make the whole assembly pop. I know it wasn't your part of the project, but it'll make the overall better
Those have such impact! Stunning is the word that comes to mind. A very fitting handle for a tamper that has special value to this lady....Well done!
I am not a coffee drinker, but I made my wife a stirring thing for coffee on my 3d printer....it stirs a measurer....now I see this tamper....what the deal with coffee...I thought you just threw some in a pot and it brewed, now I see all this, I am confused...
Those are for expresso machines, it's a special process to compress the ground coffee into a puck type shape
We actually talked about that when he brought the heads to me. Normally I would epoxy the threads on the stud that connects the head and handle but I did not on these so He could clean up the head. He already did the brass one since I gave it to him Monday.
View attachment 376728View attachment 376729
Beautiful pieces!
I'm curious, do bottle stopper blanks work for tampers or what size blank?
Nice nice. I just hated seeing your clean work next to (in my opinion) unfinished parts.
Beautiful pieces!
The blank must be slightly larger than you want the finished piece to be.
I don't think there is a 'standard' stopper blank (or for that matter, a standard blank for anything). In the case of coffee tampers, the notion of 'standard' is even more illusive because there are so few manufacturers who sell the metal bottom for coffee tampers. I made myself a coffee tamper back when I first got started in wood turning, and my search only turned up two suppliers - one outside Seattle, and the other in BC (Canada). Curious that they were so close to each other - guess it has to do with the fact that the folks in those parts are particular about their coffee. But both offered tamper bases with a 3/8"x16tpi thread which happens to match popular wine stopper mandrels.. But the key dimension was the diameter of the flat top - where the metal meets the turning. As I recall, it was a relatively simple matter of measuring that dimension, and then turning to match.
And by the way, there is no rule that says the tamper must have a metal base. You could make the whole thing from wood if that's your preference.
Thank you! Very helpful information.
Very nice Here's one I made
Stunning!!!
Absolutely beautiful. I made mine from a PSI KIT with screw in insert. How did you attach the turning to the coffee tamper ?
The tamper head was tapped for a 3/8 stud so I just cut off a bolt for the stud and tapped the handle. I put a little epoxy on both pieces before I threaded it all together.
