John Fiorello
Hi! Totally new to pen building and this forum, I've spent a week or so focused on learning as much as I can on the subject and the biggest barrier I have is how to get started building this specific type of pen (in the picture). I've been through all the getting started blogs and tools lists, but I just can't seem to find a kit (or whatever you'd call it) that just has the parts I'm looking for. Checking all the vendors linked here, most sell kits with wood, or parts for pens I don't want to try yet, so I thought posting here might help
Could you take a quick look at the picture and tell me if I can buy a kit that just has the things the arrows are pointing to? I'm also assuming there are barrels in the top and the bottom you can't see (but I don't know what size to buy because I think it depends on the click cap dimensions and the clip diameter. This pen uses the Jinhao ink cartridges.
I have all the tools I think I'll need except for the mandrel for turning, but even that seems like it might be optional if I'm building in two sections and using a live center. I'm glad to buy one if I need it, but they seem like they're different sizes and I'm not sure how to measure this to see what size it needs to be.
I'm going to try and turn on a Shopsmith (which I know is a bit big for this) with a chuck on one side and a live center on the other side. Does anyone here use one of those? I could use any getting started tips on that big of a machine.
Thanks, everyone, and looking forward to learning more about what I thought was going to be an easy hobby to try
Thanks,
JF
- It seems most kits screw the part #3 onto the part #5, but I was hoping to do a snap cap.
- The nib section #4 is plastic (I'm ok with metal instead) but it screws into the #5 part, is that a separate part glued in to the brass tube? Or is it a sleeve that's glued/pressed into the wood section?
- What is part #6 called?
Thanks,
JF
