FIrst Label Cast using John Underhill Vertical Casting System
egnald
Columbus, Nebraska, USA
Greetings fellow IAP members,
Today I did my first Label Cast using John Underhill's Vertical Casting System. I prepared 4 Cigar Cap-end tubes using a generic whisky barrel designed label printed on matt labels from Exotic Blanks. I cast them with Alumilite Clear Slow and had them under 55 PSI for 4 hours. It produced 3 out of 4 usable blanks. (Pictures Follow). I intend on making the Cigar Tip-ends with Oak Whisky Barrel blanks.
Lessons learned:
1) Be more careful about the edges of the label when coloring them with the Sharpie before sticking them to the tube. I will probably wipe the tube down with denatured alcohol to make sure there is no oil of any kind on it that might hamper adhesion. Then I will lightly burnish the seam with something to insure that it is sealed down well. (The seam came loose on the failed blank -- fortunately this is also the one that was the most off-center too).
2) Press the silicone stopper more firmly onto the nail in the Delrin bottom plug to prevent a skin of resin from creeping between the plug and the stopper if at all possible. (I had to cut away at some of them in order to pull the bottom stopper out. The hole left behind by the nail helped me get a pick under the excess resin so I could get it pulled off).
3) Be more meticulous about bending the wire on the top around to center the tube as best as I can. (As you can see in the pictures, I didn't do a very good job of centering, but I think there is plenty of resin surrounding the tube so it will make a good pen).
4) Pour the resin more carefully and only pour about half the way up on the top silicone stopper to prevent a skin of resin from forming on top of the plug. (I had to cut away at some of them in order to pull the top stopper out).
I must say, the thrill of pulling these out of the pressure pot was quite intense. John's casting system worked great even considering my inexperience with it. I'm looking forward to making the next one -- and to turning one of the blanks tomorrow.
Dave
PS Due to reflections and such, the pictures do not do justice to the clarity of the resin. The label backgrounds are jet black and not the dark grey-ish that they look like in the pictures. The detail in the label is also much greater than what the pictures show. (The little side note that can be seen in the picture by the seam says "Made using a Stave from a Genuine Barrel once used to Age Whisky").
Congrats Dave! I'm glad the casts were successful. They look great.
Moving forward, make sure you leave around 1/8"-1/4" overlap with the labels. They stick better to themselves than the brass. As for the bottom plug. I often have resin covering them also. I just use a pair of needle nose pliers to pouch through at the small nail hole and break the excess resin away. The resin might be a little flexible when first out of the mold but after an hour or more it will harden more and break off easier.
As for the wire, sometimes the resin cures in the tube at different areas so it's possible for the brass tube to be pushed a bit, moving it out of center. In all my years, and some were without a wire, even if the tube leaned, there was only one time I can remember that there wasn't enough resin. The tapered plugs should hit the clear tube mold keeping the brass tube far enough out that they will work with the bushings.
Thanks for posting and feel free to reach out with any questions. Congrats again!
One thing I would caution you on is using sharpie. Some sharpies will not mix well with resin and destroy the blank. Make sure it is a permanent marker and Let dry. Speaking from experience.
Lessons learned:
Dave
View attachment 374098 View attachment 374097
Old thread I know, but I wanted to give you another tip on the labels. As John mentioned give a slight overlap, and in my case in the beginning that wasn't always enough even with burnishing the seam. Everyone I do now I use a cheap package of hobby paint brushes and I brush a THIN layer of CA down the seam to seal it fully.
Since I started doing that I have not had a single label pullback when casting, in over 4 years. Little extra Piece of mind
