Sharpen Carbide Inserts
Todd in PA
Port Matilda, PA
I'm sure most of you know this, but I only just learned today that carbide inserts are re-sharpenable. Who knew! 🤷 Not me!
It turns out to be super easy also. Turn it upside down on a diamond plate and make circles.
Thought I'd share in case there was someone else like me who is throwing these out when they get dull.
Thanks for the link, Todd.
I found a similar video by Stumpy Nubs a year or so ago and have been using a diamond plate and lapping fluid to resharpen ever since. I'd suggest I can get them 70-75% back to original.
Beats the heck out of dull, but not as nice as using a new one.
I have been resharpening the "non-negative-rake" cutters for several years now. I use the various grades (course to fine) diamond plates. I read somewhere that Krud Kutter is a good lapping fluid for carbide cutters, and I have been using that. It works quite well.
Works fine for ones that are just plain dull , as opposed to those with nicks out of the carbide . Nicks usually occur when the cutter is used to round the corners of a stabilized blank .
Or if you're a knucklehead like me and drop your tool on the concrete.
It'll chip the carbide bit quite nicely.
well... not really. it puts the burr on the wrong side so this is more akin to honing than sharpening, and it dulls quickly. think of the edge of a chisel blade - when you sharpen it, you don't put the back of the chisel on the sharpening stone.
properly sharpening carbide needs to be done with a holder that puts it at the correct angle. i'm surprised there aren't more jigs available to facilitate this!
