Segmented Bowls
RGABEL
Beaver Dam, WI
Started down the segmented bowl path and quickly got addicted (just like pen making). Here are my most recent creations.
  • 20240319_054217[1].mp4
    31.6 MB
I've built the segmenting jigs but have yet to start on a bowl. How difficult did you find it t first? And what software do you use to determine the dimensions?
I did not find it difficult to do. I upsized my segment widths to give me a little more tolerance. The hardest part I found is gluing the rings together and keeping them relatively concentric (why I went with wider widths). I glued them off of the lathe which makes it a little more difficult. The other challenge for me is sanding the disks flat before gluing. I made a large disk sander jig for my lathe. The "spiral" bowl is 3/8" thick segments which were difficult to hold on the sander. Burned some holes in work gloves that I used. A drum sander would be much better.
For my first bowl I used scraps in case there were issues.
I use the Woodturner Pro suite for design. There are tutorials on how to use it on the website. There is a trial period for the software that does not have any limitations so you can try it out before buying.
If you have any questions feel free to message me.
  • Like
Reactions: Lew
