Longworth Type Chuck
PreacherJon
Indiana
Ron Brown makes some really good stuff! I bought my longworth directly from him and it has been excellent. A great time saver compared to cole jaws.
RichAldrich
Colorado Springs, CO
I have the Ron Brown longworth chucks. The 12 and 16 inch. Both are out of round. The are too flexible if trying to use as a press on the tail stock. Stick with the metal or have a cnc person make you your own so it is concentric.
greenacres2
Northwest IN
I have both Nova-Cole and a Longworth. For holding, i'd give the Cole jaw an edge, especially with the kind of squared buttons ( https://www.teknatool.com/products/chuck-accessories/nova-cole-jaw-buffer-accessory/ ). Downside is that i've never used them without having to change the 8 button locations--it doesn't take that long, but it feels like forever when i want to finish a bottom.
For convenience--i'd give the Longworth an edge since it just kind of spins into position. With a 16" lathe, my 16" Longworth also gives me larger diameter capacity, which my not be applicable to you Lee. I also prefer the Longworth for internal holding for undercut rims, though i honestly don't know why!!
Gary Beasley
Marietta, Ga. USA
I like my longworth for centering rings as I glue up. I made a set of flat wood buttons to handle that job more efficiently. It doesn't take a whole lot of pressure to set the ring in place as I rotate and rub the joint as its centered causing the glue to grab fairly quickly.
leehljp
Member Liaison
Tunica, Mississippi,
Thank you fellows, for your input, experience and insights. This really helps me understand the differences and potential. Thanks again!
PreacherJon
Indiana
Are you spinning them faster than recommended?
