Hippie3180
My husband works in a line of work that sees much tragedy this time of year due to fire. Please think things through when trying to stay warm
Don't use the oven, range as a heat source.
Never run power from one house to another via an extension cord.
When using heat lamps for animals, keep them safe from toppling over. Secure them up higher than where the animals are.
When using space heaters, keep a 3' area of clearance all the way around.
Please be sure your smoke alarms/carbon monoxide detectors are properly working. Never take out batteries to put them in your remote.
Never plug space heaters into power strips.
Be sure extension cords are in good condition and don't place heavy objects on top of them.
Never use a grill indoors as a heat source.
Be sure to properly ventilate when using gas powered generators.
If your car gets stuck in the snow, be sure to clear your muffler to prevent carbon monoxide poisoning.
Always consider volatile fumes and open heat sources.
And first and foremost, please check on each other, especially those who may be underserved.
