Hippie3180
So, I tried my first Alumilite blanks, they looked good on the outside, drilled fine but the texture is weird on the inside. Chalky weird like. I measured carefully only perhaps a 100th difference between A and B. I mixed well and had plenty of time to mix my individual three colors. Under pressure 55lbs for 4 hours. We're thinking too much mica to the divided parts of Alumilite, is this a possibility?
Also, after demolding how long should you hold off before turning?
Also, I should say that I'm using Alumilite Clear Slow. I should also say that I'm making a relatively small batch, 4/ @ 3/4 x 8/34 rods. In a silicone mold.
