Hippie3180
Where can I find the tiny set screws that are on the outside of the die to tighten it down? I may have dropped one never to be found again.
			Just about anywhere but you need to know the size. It is a machine screw. Usually they come in allen key head style. Start there and type that in google and it will help.Where can I find the tiny set screws that are on the outside of the die to tighten it down? I may have dropped one never to be found again.![]()
Yes and I believe Home Depot still has those oddball bins that they sell things like that.Ace or True value. Bring the die.
Mike
That would be my first choice to look, particularly if you don't know the size of the screw.Ace or True value. Bring the die.
Mike
Second this! Ace around here, always have every kind of screw type thing you can imagine, in every size possible. No better place to find tiny grub screws or things like that.Ace or True value. Bring the die.
Mike
Yes, extras are a good idea, it's not the first time I've dropped one.You could still take it (one) to a hardware store to identify it and get a (some) spares. - Dave
Doesn't always work. I have 2 missing pen kits after buying another to replace the first one that disappeared.The best way to find anything is to buy the replacement. Then the missing part will magically appear out of thin air.
Most certainly.Monty, do you believe in gremlins? They collect things and carry them in another dimension.
