Pre Drilled 5/8th acrylic blanks
WriteON
Florida & Pa
PSI is not showing a good inventory. Please suggest a vendor. Only looking for Pre Drilled 5/8th acrylic blanks. Thanks...
I have searched for the same recently also. Really hard to find and if you do, they are expensive. Not sure about you, but the 5/8" hole for me would be for call blanks.
Why are you limiting yourself to a certain thickness and pre drilled??
I'm turning Dog pens. Maybe 10-12 on top of the 9 I just finished . I can turn several round 5/8th blanks before I drill and turn 1 square blank. They are a time saver and I'm getting old and lazy. If for 1 or 2 pens the square blanks are fine.
Sorry...need to clarify... the blanks are 5/8th round with a pre drilled 7mm hole. They are fast to cut to length. I run a 3/8 bit to enlarge the hole. Saves a lot of time. I'm donating these to various charities. I can produce quickly after they are squared. It cost more than it should on my end and they get sold too cheap on the other end...but I'm having fun.
I have been donating to Fox Chase Cancer Centers "Paws for the Cause". It's a day of vendors, gift basket raffles, etc. Outdoor event where people bring their dogs and stroll on the grounds. It would be easier and cheaper to simply write a donation check than to turn a dozen pens but it makes the event more joyful.
