Top barrel not snug enough on transmission - help
Ron7413
The Great State of Texas
Hi! -- I've made about 10 pens so far and am still learning. Here is a pen I made yesterday. It is a modified slimline with the center band glued to the top barrel. The problem I'm having is that the top barrel does not have a snug fit onto the transmission. So when I rotate the transmission to the closed (pen retracted) position I can easily continue rotating the barrel which causes the grain to get mis-aligned. Is there any easy way to snug-up the fit between the top wood barrel and the transmission? FWIW, the brass tube in the top barrel does extend through the center band. Thanks!
You can put some CA glue on a q-tip and wipe the inside of the tube with it. Let it dry completely (overnight). One light coat is usually enough to fix that sort of problem, but sometimes a second light coat might be needed.
I'm not sure I understand how the indent dimples would make the top barrel fit snugger. I would think the dimples would have to be proud of the transmission surface (an 'outtie') rather than an indent (an 'innie'). What am I missing?
It has to do with how metal stretches and deforms because of the impact. It gives you a result similar to what you would get from shot peening a surface. You get dimples, but it also raises the metal slightly around the dimples as the compressive forces not only stretch the metal downward but also push it outward around the point - and since it can't push outward because of the rest of the metal it pushes upward around the dimple.
See how the material that is shot peened is "raised" in the photo below. - It kind of works like that, but only around the individual spots.
I hope that helps. - Dave
Peened surface (raises the surface)
Thanks Dave...much better than I could have explained.
Thanks, Dave, for taking the time to respond and providing such a great explanation. I understand the idea now. Thanks again - Ron
Dave, you are awesome.
Taking your time for posts like this one have really added to my general knowledge bank.
And I am not poking fun. I know sometimes this kind of communication can be misconstrued for a joke or sarcasm.
Thanks,
Mike
Use one of these and place a few "dimples" on the transmission. (spring loaded punch)
Don and Dave - I tried to place a dimple on the transmission using a spring-loaded punch, but it jammed the transmission. I believe the dimple is preventing the threaded inner barrel from moving up and down. I wound up pulling out the transmission and then putting a new transmission in. I then put some thin CA glue in the upper brass tube as suggested by Edgar and that seems to have worked.
Don and Dave - I tried to place a dimple on the transmission using a spring-loaded punch, but it jammed the transmission. I believe the dimple is preventing the threaded inner barrel from moving up and down. I wound up pulling out the transmission and then putting a new transmission in. I then put some thin CA glue in the upper brass tube as suggested by Edgar and that seems to have worked. View attachment 360905
I'm really glad you got it working.
I am thinking that if you want to dimple an unsupported tube, you need a punch with a very thin point and a 4 ounce hammer. Then tap lightly. My automatic punches like that are adjustable, but even on lightest setting leave a pretty good mark. A tight fitting hardwood dowel would also help, but with the transmission inside there, wouldn't fit.
Glad you got it fixed.
Mike
