Jim, I am a little surprised at this. Just about every Epoxy type I have ever purchased going back 40 - 50 years states in the instructions that the CURE time is xxx, which is longer than the set time. I say that, because I have always check a new brand (new to me) as to the cure time. It should be on the instructions of each.
As to a toaster oven, every person will use it differently and every person's milage might vary; That said, don't get it too hot. The cheaper toasters might not have an actual temp that will be below 175°, which can destroy epoxy's strength. It could be just me, but I have ruined a few glue-ups by heating them a little too high.
I would like to see others experience in this area of overheating epoxy, and at what temp does that occur.
Jon Rista posted this:
https://www.penturners.org/threads/t88-a-useful-paper.178952/#post-2197341
the paper has this in it:
| Lap-Shear Strength vs. Temperature (Aluminum Tensile Shear) | 67°F: 2,500 psi, 75°F: 2,000 psi, 150°F: 1,300 psi, 180°F: 1,000 psi |
| Heat Deflection Temperature | 119°F (49°C) |
| Maximum Service Temperature | 160°F (71°C) |
| Minimum Application Temperature | 35°F (2°C) |
| Gel Time @ 77°F (25°C) | 60 Minutes (100g mixture) |
NOTICE the Temp variance in the Lap Shear Strength vx Temperature. Shear strength decreases with temp increase. Max service item is 160°. I mention this because an inexpensive toaster oven does not regulate the temp very well and the dial temp setting is an estimate at best.
