Wood ID?
keithbyrd
Mount Wolf, PA
Customer brought me this piece of wood from a hike to the top of Mt Kilimanjaro. Any thoughts on the type of wood? Its not heavy like a dense wood would be, but this is probably the hardest wood I have ever turned. It produces more dust than shavings!
Does the customer have any more of that wood? Very cool stuff.
G
I haven't seen that before! And I did a search of Kilimanjaro trees. The search kept trying to move me to plants.
You have a friend for sure. When I lived in Japan, friends from SE Asian countries always brought me some wood from the country where they worked. Great Friends!
Thanks Hank! I had the same experience searching for trees and non of the bushes I saw grew like that!
Ran across this : https://empressfurniture.com/properties-of-tanzanian-timber/
From the hardness you mention, I wonder if it might be teak vis-a-vis
"the highest quality teak wood will have a golden brown colour. The real teak wood has a long, straight grain. The low-quality teak wood will feature larger knots"
But (assuming) it was found on the side of the mountain itself, this line about Podocarpus usambarensis makes it a possibility too.
"Podocarpus usambarensis is a tree growing in highland rain forests, in altitudes of 950-2,700 m. (ed note - Kiliminjaro goes up to 5800 meters) In Tanzania it is found in Kilimanjaro, Pare, Usambara, Iringa, Mbulu, Njombe and Uluguru .... There are two varieties in Tanzania: P. usambarensis war usambarensis found in highland areas"
Searching for that later term comes up with this : https://www.conifers.org/po/Afrocarpus_usambarensis.php
This line leapt out : "Bark dark brown turning gray with age, forming small angular plates, flaking."
And there's about 4 others on the original link, and the wood database has two listings for woods from Tanzania - https://www.wood-database.com/leadwood/ and https://www.wood-database.com/african-crabwood/
Darios - Thank you! I appreciate the efforts you took to do the research! It certainly sounds like what I have here! I will follow up on your research this afternoon!
Well I read a lt of the descriptions of the various plants and trees on Kilimanjaro - based on what I read I rather go with African yellow wood or acacia. Because of the way it has aged and the reddish colors in the wood I am going to go with Tasmanian Acacia!
Thanks for all your help!
Will finish the pen post a picture in the next few days!
