Jet 2hp dust collector
cl1237
Lancaster, OH
Jet 2hp dust collector 220v.
Bought from a local pen turner. Brought it home and found out my ceiling is too low to use it so I never had an electrician run an outlet for it. Taking up space in my small shop.
$450
Pickup Lancaster, Ohio
$450
You might check on a Wen filter. I think they're a bit shorter in height and do a much better job of filtering the dust.
I had a similar height issue with my Delta dust collector. I removed the caster wheels that gave me about 1.5 inches extra clearance.
Wen, Wynn, yes, the canister filter. The canister filters down to the .3 micron level as I recall. Huge difference from the 3-5 micron bags. The volume of fine visible dust generated BY the dust collector is gone. Lower load on the motor, greater static suction. I waited 4 years and now I wonder why.
