Mostly triangles
See more from Alan Morrison
Alan Morrison
N Ireland
A couple of pens and a blank in Sycamore and Mahogany composed of triangles and a couple of parallelograms, and an assembly photograph. Photographs not great.
Absolutely awesome work. For me, I simply don't have the kind of patience it would take, nor do I have that kind of skill. I do however admire your work and the skills it took to create it.
Thanks for your comments.
I studied a segmented pen made by Mark @mark james for two years before even attempting something like it....even with Mark's assurances that his design was very do-able. In the end I tried it and sure enough it was very do-able. Mark has written some excellent tutorials in resources
which helped me enormously.
Once you can cut equilateral triangles then these designs are most definately very do-able, and simple enough.
You should give it a try sometime.
Alan
Very well done. One of these days I am going to have to travel down this path myself. The key is to be able to cut that small of pieces safely. Using the right woods brings out the designs and you do a great job with that. Thanks for showing.
Alan
Alan, to me the hardest part would not be the cutting. It would be gluing up all those segments at angles. All in all, your work is excellent.
Those look great Alan. Your work is very inspiring. I have been studying Mark's tutorials for sometime now and recently started down the advanced segmenting (that's what I call it) road starting with the Squares and Triangles tutorial. Hopefully I will have something to post in the next week or so. It definitely takes patience and attention to detail. Your patterns remind me of many of the Yosegi designs. Very well done!
Looking forward to seeing them, John.
I am in the process of re-making these as the triangles were just a tad too big, meaning that I lost too much definition in the pattern.
I will post when completed.
Hope that you are well, John.
Alan
Thanks for your comments, Mark.
Trust that you are well.
Alan
I'm doing well my friend. I got home from my FIL yesterday, so have 4 days off. The schedule is OK. I have gotten a bug to crank up the metal lathe and cut slotted blanks for end caps. Each segmented blank takes 6-10 hrs from slotting to inlays done and cut. Less if I do 10-12 blanks at a time. But then, I also work slowly. My wife is pushing me for a better respirator, and to be cleanly shaven before I do those 😢 . She is correct (she's an industrial chemist), so when I get my new respirator, I will cut 10-15 blanks with 6-8-12 slots and do the inlays. All is well!
