The hardest part about making threaded lidded boxes is holding the bottom of the box on the lathe to finish the bottom, without damaging the threads. You can make a threaded piece for each box, but what a hassle that would be. I looked around online for a solution, didn't find much so I decided to tackle it myself. The following is what I came up with and it works perfectly. I created a set of threaded jaws that fit on my G3 Cole jaws set. I decided to use the cole jaws as a base because they have a flat surface and I didn't need to worry about an alignment grove. I used a piece of IPE, hard stuff, turned to the shape I needed, threaded it. Before taking it off the face plate, I made sure I drilled a 3/16 hole on center. Closed the cole jaws on a 3/16 brass rod and slid the threaded on top. From there I clamped it down, screwed a sharpened bolt, from the backside to mark my drill locations, After drilling them all and countersinks added I made sure to mark the cole jaws and the homemade piece with jaw numbers. They have to be in order when using. I marked the piece where I need to separate them. The last step was to remove the piece from the cole jaws and cut it into quarters and then just bolt them back on. Pictures show three different size threaded boxes all fitting perfectly, no need to make a special part for every box. These should work for openings approximately 2.5 to 3.75.
