AllanS
Just as an experiment on a 'learnin' pen'* I played around with Gorilla glue due to see if it will help with the number of blow outs I'm getting ala the Loctite GO2 failure thread, here's a couple of data points that i just found out
For me I think I'm going to avoid Gorilla glue etc for any segmented pens I'm working on. That being said, the foaming/expanding aspect appeals to me on non segmented pens as I too tend to see large 'dry' spots where there is no glue on those times when I have a blank blow out.
* Ala Fred Bruche's "Sometimes you win, sometimes you learn"
| Gorilla glue foaming out through gaps in the segmenting. That was actually a pretty snug fit for the segmenting too, needing a few seconds on the belt sander to thin the segment down enough to just fit. This was with the end clamped closed to keep the tube from potentially being pushed out. That expanding foam had to go somewhere. But the CA that glued the segment in held it in place. | |
| The shine line dampens the impact, but there is a very visual hiccup at that point in the pen. The same issue can be seen at the other side of the segment. | |
| On the scallops side the gorilla glue got in there and pressed open the segment. Segment was glued down with epoxy (either Mercury or T88, I can't remember which line of effort this happened on). I was able to get in there in time and clamp down the segment before the glue set. |
