Step less #2 in Ceboplast
See more from PatrickR
PatrickR
Rural America
13mm Step less design. #6 Bock nib. Serpentine Ceboplast with silver casein and red acrylic rings. Ebonite section and a blind cap.
13mm Barrel
14.8mm cap
134mm long
20g (without ink)
Q, C & c welcome.
Love it, looks awesome!
How does it feel with the .9mm cap wall? I'm always scared to thin the wall too much.
What are you using for a stop, since it is stepless.
it feels solid. I don't think its too thin. Dropping etc won't be an issue but I wouldn't want to sit on it. The last one I made from alumilite and it was definitely more flexible than this is.
it stops on the section lip. I have kept it wide and square so that it seats firmly on a step down inside the cap.
Thank you for the response.
You are welcome.
take a look here
at the bottom is a picture of the prototype. The cap portion has a 13mm through hole. once the black piece (9mm through hole) is screwed into the top, this is how the inside of the cap is shaped. I use these pieces to determine where the stop is located, screwing it in or out to get the stop where its needed in the final pen.
