Straight edge razor kit?
See more from cenogene
Here is one source and is made in USA:
Jay
Note that the description indicates the blade has not been hollow-ground or heat treated. I've looked extensively for these, as I've had multiple requests from clients. The only thing I've found have been in the multiple hundreds of dollars.
You may be better off buying a premade blade and replacing the handle with one of your own.
Thanks for the intel. I've considered doing that if I had to. I'll hold out awhile longer and hope I can locate another source. Thanks for chiming in!
There are two different blades on that site, one has been hollow ground and heat treated, the other has not been see attached screenshot
