How would you turn a book into a blank?
DaveH
Fayetteville, Georgia
I've tried to take a book and saturate the pages with ultra-thin CA to use as a blank but its not as easy as it seems. I wanted to take a damaged book authored by a friend of mine and turn the pages into a blank for a classy pen gift for his retirement. I cut the soft-covered book into one inch slices, stacked them up, and tried to infuse the pages with the CA but it doesn't get into all areas. I haven't started stabilizing yet but I think that would be challenging as well. It seems like the blank would have to already be somewhat bound together before putting it into a vacuum chamber. And, using CA for this would prevent a good stabilization. Can't get there from here maybe. Has anyone tried this yet?
The first picture is of a magazine that I tried to use. I saturated the sections with with CA before using the clamp of course.
I've used layered construction paper for segmenting. Tried CA but found white glue worked better. Kept colors from running.
There is a turner in Fort Collins, Co named Trent Bosch. He is a well known instructor in the area and his daughter has made bowls from books using plain white or yellow glue. I know if you contact him he would be willing to share info on a project like this.
You might find the info in this article. Try contacting the author.
This is only an idea, not a proven technique. Get a large enough bucket and add Cactus Juice. Dip a book into it soaking the pages, remove the book and clamp over the bucket, let it drain for a few minutes. Then bake it to cure the Cactus Juice.
Another experiment idea. Mix up a batch of resin and add some acetone to thin it. Dip the book, clamp and let ot cure. You would need a slow curing resin, and the acetone should farther slow down the curing process.
For the CHEAP people out there, again a large bucket and a quality wood gue like Tite Bond. Mix about 50/60 with water. Dip book and clamp it.
Will this work? I have no clue, just a theory that it should.
