qquake
This is a Personal twist pen from The Wooden Quill. The first problem is the instructions are wrong. In the assembly section they state, "Press the cap/clip assembly into either end of the barrel". The problem is the bushings are different sizes. The cap/clip assembly goes in the larger end. I have made these pens before, but forgot about this. I had to disassemble and reassemble it correctly.
The second problem I haven't run into before, and is perplexing. When I twist to extend the refill, it won't retract. But if I loosen the tip, it retracts. I can't figure it out. I have another kit, and tried the tip from it, but it did the same thing. Any ideas?
twist.mp419.4 MB
