Ok, for anyone still following this thread, especially you color nuts. I have all of the Gamblin pigments I ordered, including Titanium Dioxide and Ivory Black for tinting and shading. I've managed to blend all of the colors I was interested in except one class of colors: The "Turquoise/Cyan/Aquamarine" colors.
I've spent a lot of time reading and watching how people mix acrylic and oil paints to make turquoise, and some pretty dead on for the kind of color I think would fit this "retro" style. However, with these pigments, when I try to mix the way I've seen paints mixed (and, after reading some Gamblin content, it sounds like their oil paints are basically the same pigments, mixed with refined linseed oil), I get different, often much different results.
I've been trying a couple common approaches:
A. Mix white, blue, yellow where white has the highest quantity, blue a middle quantity and yellow the smallest. Adjust yellow to adjust the green/blue tone of the turquoise.
B. Mix blue, green and yellow and maybe white, blue highest, green middle, yellow smallest, with white a variable to achieve the right brightness.
In both cases, I either end up with more of a steel gray/blue, or a light sea blue, and can't ever quite seem to achieve an actual "turquoise" or "aquamarine". I don't have any refined linseed oil, all I have is boiled, which is probably just about rancid at this point, so I'm not sure that would make for a viable oil base to try and blend some pigment into just to see if the yellowing the oil introduces has an effect on mixing here.
Anyway, just curious if anyone has any thoughts. In a general sense, I've been assuming Red, Yellow, Blue mixing model, although I think technically, the blue should really be a bit lighter than the blue I am using (Cobalt Blue).
I've ordered the missing pigments from the set (I'm probably nuts for completely diving in headlong for every single pigment Gamlin offers, except maybe Zinc Oxide white, and a Mars Black now, I think...I've dropped hundreds of dollars on pigments now!!
), and that includes the Veridian Green. I am wondering if the Veridian Green would help me achieve the color I am looking for, as its kind of an aqua sort of color itself...just more green than blue. I also ordered the intermediates I missed before, like Raw Umber, Raw Sienna, and Prussian Blue (which might be a perfect blue for the darker navy blue like color I've been looking for, maybe with minor adjustments). Hopefully with a broader palette to mix from, I'll be able to achieve some of these more challenging colors.
