Cutting Corners with Bandsaw
Wmcullen
Fairfax, Virginia
I'm not sure if this process is right or wrong; unique or common. But I want to share in case it's interesting.​
28: Cutting Corners with Bandsaw
last post- 27: Customized Zero Clearance Bandsaw Peg Jig
(3d *.obj file attached)
Tony mentioned he uses his bandsaw to remove corners from brittle blanks before turning.
We started talking about developing a simple 3d printed blank holder.​
The Problem
Cutting a blank at 45 degrees freehand feels like a fast way to have a problem.
Our Solution
(Not rocket surgery.)
Print a v-grooved sled to hold a squared blank and keep our fingers further away from the cutting.
The jig accommodates square blanks from 5/8" to 1". It is intended for rough cuts. Precision is not one of its traits.
*Optional Stop Block Attachment
We designed an extra piece that can be CA glued to the bottom of the jig and used in conjunction with a 1" wide x 0.25" tall stop block (not provided). This way the sled would glide along without having to eyeball the cut.
3D Model
Attached is an obj file called CornerShave4.obj
The model is provided as-is. A bandsaw blade will go through this plastic like a hot knife through butter. I never rely on printed plastic for protection. I only use this to keep my fingers far away from the blade.
Thanks for looking!
- Cullen
Forgive me if I am missing something here...If you're a woodturner why do you need a bandsaw to cut the corners?
I always trim the corners of acrylic blanks before I start turning them. Makes it easier to rough them round, and they're less prone to chipping.
Watch
Listen
Learn
New ideas are great
Especially when they can
Save tools
Have safety features
I'm sure you are well rounded, experienced
woodturner/worker/tradesman
Please share your tips & tricks
so that we all can learn something
new
Thank you
First: I speak only for myself and what I do.
Second: Like @qquake, I do it on the plastic (e.g., acrylic) blanks. I have not found a need to do it on wood blanks.
Third: I have not used a bandsaw for a while. Instead, I prefer to use a belt sander to accomplish the same results.
I clamp the plastic pen blank by the ends using a ratchet clamp, and sand off the corner edges using a belt sander. Pay attention to even sanding along the edge (not too much top or too much bottom). Roll the blank as you sand to make a smooth, round, corner edge.
Why? It helps to prevent chipouts. It also means less of the "hard work" on my roughing gouge, which means less time spent sharpening.
CAUTION: Using a belt sander creates a lot of very fine plastic dust with lots of static electricity. It clings to everything and doesn't like to blow or vacuum off. I put a shop vac at the end of the sanding belt to collect the dust.
I made a jig to do this on my bandsaw by making a couple of octagonal pieces of wood with a quarter-20 ready bolt through them and a quick release knob. I mount the drilled and tubed blanks with the bushings and spacers, then use the fence on my bandsaw as a guide for the jig. It uses the tube as a reference so the octagonal blanks are concentric with the tube and not necessarily the center of the blank. By cutting on all 8 surfaces it permits more bulk of a blank to be removed rather than just nipping the corners off. It was easy to make. The pictures provide a better explanation than I could ever hope to. - Dave
One doesn't need one. It is just an option. I practice this more for non-wood materials. It not a must..just another way of going about it.
Artie, cutting the corners off a blank is one of those things that some do and some don't find a need. I am one who does not find a need. Others think they save on wear of their tools but again I believe it comes down to being able to control your tools and to sharpen them well. I have never found a problem turning square stock round weather acrylic or wood. Just takes a light touch to get it round. Now of course if segmenting this could be a great way to equalize a blank for an octagon. You find there are many ways to get to final product. some use CA some use other things. Some use epoxy and some use CA to glue tubes in. again whatever you feel comfortable to do. But the thing is find out what works for you. Make take some trial and error but you will get there.
Hi Artie-
I thought the SAME thing when I heard the question. But when someone mentioned they were turning "brittle" material it made a lot more sense. Thanks for asking the question.
Thanks for chiming in Dave. Your jig has been a great inspiration!!
First off, let me applaud your design and fabrication on the jig. It's beautiful.
That said, I still don't quite understand why you need it. I get trimming the corners of the blank. What I don't understand is why you would want this jig versus just tilting the table of the band saw 45 degrees? Am I missing something?
Everyone is different and each one has his on preferences. I do like the jig vs using a table saw. I have used a TS a couple of times with a home made jig, but I too prefer the BS and a jig. And I sometimes use a round over bit in my router table. Works great.
AS to a TS and tilting the TS blade, " to me," - if the blank is under the 45° blade, that is extremely dangerous, even with a jig. If the blank is on the outside, the base is being cut out from under it, making for potential danger too. Even using this jig on a 90° TS blade would be safer than using it on a tilted blade.
I have some jigs like this, not to round off turning blanks, but to make flat sides on tool handles. This is to keep the tool from rolling off the table.
The only time I remove the corners is when I am getting ready to turn a "million piece" segmented blank, but the I load it up on the lathe, turn on the lathe and use a "40 grit" skew on an angle grinder and sand it to round.
View attachment 321804 View attachment 321805
This is really cool. Lets you use the fence to guide and keep the cuts very strait. I have to give this a try.
I get what you are saying and it is absolutely true that tilting the blade on a table saw could make for some dicey situations. However, I was asking about tilting the table on a band saw which, I thought, would accomplish the same thing as the jig.
Sorry for the misunderstanding.
I once had a 12" craftsman band saw in which the blade tilted and the table stayed level. That was a sweet BS, and made for easy miter cuts rather than tilting a table. I miss that saw.
Wood I never take the corners off. I used to not take the corners off of plastics. After trying it, it is actually slightly faster to take the corners off and a good deal more pleasant since I don't get plastic chips bouncing off my face mask. Once the blank is round plastics are fun to turn. done correctly you get a continuous ribbon that gets sucked straight into the vacuum.
Aurelius: Great point. Thanks for adding it!
Cutting Corners with Bandsaw - UPDATE
Tony and I decided to increase the distance between the finger guard and blank.
He reports that this version is just as easy to handle.
The only (slight) downside is that the pieces don't fit into a single print.
Therefore, I'm including the geometry (obj files) as two separate files.
Best,
Cullen
Best,
Cullen
If anyone is selling these, I would be happy to buy one. I tried making my own jig, but it didn't work out as I had hoped. PM me if with a price which I'm sure will be less than me buying a 3D printer :)
@Wmcullen just wanted to say thank you for providing the 3d files. I just started a print on these to see how they come out.
FYI the .obj files are incredibly small, around ~4mm. I had to scale up 1000% for a workable size.
You're welcome. I'm happy to share.
While I build my models in inches, when it comes time to turn into gcode I always need to scale up 10x in Cura.
The nice thing is that the measurements come out perfect when I do that.
Thanks for the note.
@Wmcullen I made a simpler design, but I like yours much better. However, I have several problems when trying to print.
1: My slicer (Prusaslicer) gives an error when trying to load the .obj file. 2: When I import it into Meshmixer and convert to an .stl, it's way too small. 3: The finger guard section appears to have part of the guard 'embedded' into the top surface as there is geometry under the top surface. 4: Not clear to me if the two columns are attached to the base? Are they printed separately and glued-on?
Thanks for the great design.
Tony
When you convert to an .stl you will also want to scale up 1000%. That will be the full size. I also had to turn the object so that it sits flat on the printer. It printed with no issue for me. The columns are printed to the base.
BTW..I printed the update, not the first file in this thread.
@hooked - As always, thanks for the assist!
@Twojugs - I agree with hooked: using the second version, found halfway down the comments, might make a better print. And yes, my obj files often need to be scaled up 10x and flipped 90 degrees. Hope it's helpful and, as always, inspect the final print and only use if you're comfortable it will improve things for you.
Best,
Cullen
I think it's a brilliant idea for increased safety. I made a wood version some time back but 3D looks a good way to go too.
Great thing about this site is it encourages thinking "outside the box" and like advice one can take it or leave it.
Thanks Cullen
I never use plastics. wood, animal parts, or stone.
I use a veneer trimer on the tool post to make my cuts that are done on a lathe.
Like a hot knife through butter ............
If I cut the corners the wood is used for inlays.
You do realize that most here do not have access to metal lathes?
Hi @alanha
Thanks for the question. I'm happy to post these models (as-is) so people can have them printed somewhere. I don't have a 3d printing service to recommend. I'm a little sorry that national chains like "office depot" and "staples" haven't brought this service to their local shops, but I guess it's still a bit specialized. If you can't find a place to have the file printed, DM me and maybe we can work something out. In the past I've printed and mailed in exchange for you making a donation to a charity.
In case it's interesting, I also put together a scribing tool that marks where to cut pen blanks into octagonal shapes. Link
Thanks for looking at my post,
- Cullen
