harik.raif
Hi, I am having a couple of problems making pentel mechanical pencils. I guess I'll split this into two posts.
1) drilling.
I have purchased a nice stepped drill bit and mandrel from ... beautiful something
. My crappy drill press only has like 2" or 1 7/8" travel and really doesn't seem usable for drilling these blanks which are 4-3/8" long. So I have been drilling them on my lathe. Problem is of course, they are square, or more precisely rectangular. I rough turn the blank down a bit and create a 5/8" tenon so to speak. I created a sort of clamp ... thing. I think someone on here probably advised me. I put a piece of wood in my chuck, drilled a 5/8" hole, then cut a kerf ( sp? ) from the hole to the edge. Then once it's back in the chuck I can tighten it down, sort of, and it grips the blank, sort of.
The main problem is that I can't get the bit to drill straight. I starts wobbling and then gets worse then pokes out the side at about 3 + inches. Some things I've checked/tried:
1) the head and tail stock are aligned
2) pre-drilling, just like goldie locks with a thin bit a medium bit and the same size bit but a short one. I put the bit in the chuck as far as possible making it as short as possible to provide the most rigidity. While this helps it does not solve the problem.
3) I've tried with the lathe turning very fast as well as slow. It seems when it's going very fast at the beginning it might be a little better.
I burned through 4 blanks the other day trying to get 4 usable ones ... so 8 total.
Not sure what else I should try. Any suggestions would be appreciated.
1) drilling.
