I tried to make a segmented blank for the first time, and it fell apart while sanding.  At a high level, I did a simplified plastic/resin version of a celtic knot style blank.  Here are the specific steps:
(a) Sandwiched red plexiglass between white pickguard plastic; all surfaces sanded and laminated with CA glue.
(b) cut a green acrylic pen blank at a 45 degree angle
(c) CA glued the green blank back together, but with the red & white laminated (from "a") in between
(d) cut the green blank again, bisecting the red & white laminate
(e) CA glued it back together with another square of red & white laminate ==> result is an "X" pattern of red & white laminate
(f) cut the blank in half at the intersection of the "X"
(g) CA glued a blue piece of plexiglass into the final cut.
At this point, I have a green acrylic blank with the "X" from the red & white laminate; and the X is cut in half with a sliver of blue plexiglass.
The blank has been left to dry for more than a week.
I cut it to size, drill it out and glue in the sanded brass tubes.
I turn it successfully on the lathe.
When I sand it, the red & white parts fall off.
Suggestions?
Suggestions?
