Gluing aluminum and brass to wood
Brumar72
Italy
Hi all,
How it's the right section for my question: I've tried segmentation with aluminum but when drilling the segmented glued blank with big drilling buts (for making fountain of roller pens) the metal detached from the wood.
I tried with polyurethane glue, epoxy, and CA but always the same story: the bond in not strong enough. I also sanded the aluminum and cleaned it with alcohol but with no results.
I'm asking you, more expert in segmentation, how to solve the issue and get a strong bond.
Thanks a lot.
Alan Morrison
N Ireland
Heat is the enemy. Go slowly and cool the drill bit down.
I normally pre-drill the aluminium and thread it onto the tube when assembling the segments.
Hope this helps.
Alan
More4dan
Katy, TX
It may just be the drilling causing the issue. Start with a smaller bit and increase the hole with multiple bits stepping up to the final hole size. The torque from large bit will shear the glued joint. Also make sure the temperature stays cool. At about 200-250 degF the glues you've tried will start to break down.
Danny
Well Marco you have found a dilemma that we segmenters deal with all the time and it is challenging. I can speak for myself because I do alot of segmenting with various materials. When working with metals and acrylics the material has no open grain to it where adhesives can seep into and attach like wood fibers. So this is why it is challenging and we rely on a very thin adhesive layer to keep things together. Then when drilling we put pressure on this joint and depending the complexity of this joint it can snap off easily.
Now with that said there are tricks that are used to this day.In fact there is a thread going on right now that talks to this very problem so to show you it is an ongoing problem. Here is the link to that thread.
https://www.penturners.org/threads/trying-the-make-brick-pattern.168814/
Now some quick suggestions that may help and if you do not understand just ask questions. There is a couple methods to make a segmented blank. One is called build on tube and the other is basically called build and then drill. what this means is if you are doing basic segmenting where you are stacking segments on top of each other such as rings then you can cut these pieces and drill them before you stack them. Takes the drilling pressure off the joints. But if you are making complicated designs such as chevrons or scallops and things of this nature you need to build the blank before drilling to keep things lined up. This one is the challenging method. I always prefer epoxy glue. My go to glue is System3 T88 epoxy. It has a long open time and requires at least 24 hours to cure. But it is the strongest adhesive I have found.
Next there is the trick of reinforcing the blank before you put in chuck to drill it. This can be done various ways and in that thread I linked there are several examples shown. But the use of gauze wrapped around the blank with thin CA drizzled within to adhere to blank and give it outside strength. Then there is the method of adding popsicle sticks or other thin woods to build a box around it and gluing it to the blank to again reinforce the sides. Then there was the suggestion of using heat shrink material. But you get the idea. Some people can get away with just flooding the blank with CA to give it strength. Again depends on nature of blank.
Now the act of drilling. Need to use either a drill press that is accurate and no runout and vibration. The blank needs to be held secure. That is why many people drill on the lathe and it makes for a more exacting drilling operation if set p right. Then many people including me like to use the step drill method. That is start with smaller diam bits and build up to one that works with tube. Onec the hole for tube is drilled then the use of epoxy to glue tubes in will add strength to the blank from within if a good layer of glue is used. But again when turning outside forces are applied and thus sharp tools and very light cuts are needed at all times. Again you can reinforce with above methods of CA or gauze if you find a need to. I never had to do this.
One thing I forgot to mention when building the blank it is always a good idea to build it much larger than needed. I always build them at least 1" square and try to keep square till I start turning. Makes it easier to do segments and easier to clamp. Plus it gives added support to the entire blank when drilling. Also when drilling and when turning, as with any blank heat is your enemy. Keep drill bits cool by drilling slow with low RPM and backing out often to clear swarf and also when turning. light cuts wins the race. Good luck.
The more blanks you make the more tips you will pick up and develop on your own because hands on is the best teacher of all. Good luck and lets see what you got. You can check my photo album out if you want to see examples of what I do. Happy Turning.
KenB259
Michigan
Another thing that I didn't see mentioned is the drill bits themselves. When you have metal incorporated in the segmenting, you want to stick to jobber bits and you want them sharp. I don't know what kind of bits you had, but something to keep in mind.
DrDichro
Cleveland, OH
I have to drill gun grip holes all the time in composites with metal layers quite often, and didn't read it mentioned here, but high rpm with very gentle feed speed is where I avoid delam and heat buildup. Also spray air during drilling to keep cool.
I grind all my bits into bradpoints with spurs, even my carbide bits, and the spurs make a huge difference in severing fine fibers and metal layers. Just keep it sharp with diamond hone.
KenB259
Michigan
Probably just me, but I have never had good luck with bradpoints and metal.
howsitwork
Thirsk
many thanks for all the tips here folks. I am about to experiment with some fine aluminium shim I built into some blanks . 🤞🤞🤞 Well scuffed surfaces on the aluminium might help give the glue a "key"
Old Hilly
Near Wauchope, NSW, Australia
When it comes to sticking bits of metal together, look to the automotive repair industries. Some car panels are so thin that conventional welding techniques won't work and they now use adhesives. That's how they fixed the cracks in the tail-gate of my old Pathfinder. Grind, glue, patch, 2 pop rivets, credit card, done.
NGLJ
Surrey BC, Canada
Although I m thinking about it, I haven't yet tried to incorporate aluminum or other metals but my general approach to drilling is to start small, increase size gradually and of course retract the bit on a regular basis to clear debris and keep things cool. If you see smoke you or the bit is hot enough to reheat your coffee, you are in trouble. I drill on the lathe and I always drill from both ends which helps to avoid blowout when a bit exits the other end. Also, I start with 4 spur carbide end mills and finish with a brad point bit. So far the only time that I have had a blowout was when I was impatient and of course payed for it! Those who can't remember their mistakes are doomed to repeat them :)
egnald
Columbus, Nebraska, USA
Also, always scuff the metal with sandpaper to promote adhesion just you would do with a metal tube when gluing it in. Another thing is to be careful to squeeze hard enough but not so hard that you squeeze out all of the adhesive in the joint. - Dave
Not a fan of brad point bits in any type of pen making drilling. Especially metals they are not designed for that and will grab the material. Brads are acceptable with woods but even then I stay away.
farmer
NV
I live cut to size all my metal inlays next wood
On a metal lathe with veneer trimmer
if you don't have a metal make mandrel out a bolt nut and washers . place metal trim ring in mandrel and chuck up in a drill press and use metal file to file to size
