Harbor freight bearing
If all else fails, you can check with LittleMachineShop.com and find out the information for the Tapered Roller Bearings and check on Amazon. You can get a pair of them for less than $20.00.
Which Harbor Freight lathe - the full size 34706? When I did mine, I think it was an 6205zz and 6006zz bearing...I think I splurged and bought SKF I had to replace the Reeve's pulleys, as they're cheap pot metal and didn't handle getting removed. The pulleys are still available from Grizzly, I believe, for their clone. - Grizzly G5979
Here's a walk through - the HF is a clone of the JWL-1236
