Comet II spindle seems fused to bearings
Manonamission
Florida
After almost 6 years with my Comet II lathe I finally had to change the belt as it cracked. My spindle is fused to the bearings and won't budge. Any ideas on a solution?
TonyL
Georgia
replaced my bearings twice on my 1221. they might as well have been fused given how hard i had to hit the spindle to remove it. i probably would have given up if i knew that spindles can fuse to bearings. In my case they were not fused...so first be sure they aren't just difficult to remove. Jet set me a new spindle anyway even though I wasn't sure if i needed one. While the next sentence has nothing to do with your post, my problem wasn't the bearings ( I kept hearing a clicking noise). It was actually two loose set screws on the handwheel. Would have save me a lot of "pain" had I know that was the source of the clicking. Good luck!
randyrls
Harrisburg, PA 17112
Lathe Manufacturers often make the spindle oversize for the bearings. Reason: Loose spindle means an out-of-spec run out and a discarded head stock. So they make the spindle slightly oversize and use a hydraulic ram to press the bearings onto the spindle. Makes it a B****** to get spindle out.
I would call Teknatool first. Ask them on which end the spindle comes out
You can remove the spindle; I've done this on my metal lathe. These two photos show how I pulled the spindle out. The PVC is a coupling I used to "stand-off" the end where the spindle came out. But this is my metal lathe, so yours will be slightly different.
howsitwork
Thirsk
Call Teknatool but maybe consider using a joined belt , unless it's a ribbed belt , sorry I don't know that lathe.
Manonamission
Florida
Thank you all for the help. I'm going to call them tomorrow morning. I followed all the steps and it just won't budge. Even wailed on it a few times with a block of wood and a heavy mallet and got nowhere. Very frustrating.
MiteyF
Bay area
Heat is your friend when removing stuck bearings. Most tolerances for bearing fits are around +/- 0.0005" on housings (bearing OD fit) and even less for journals (bearing ID fits). A small amount of well placed heat on either the housing or bearing itself will usually give you the space you need to disassemble or reassemble.
