Silver overlay fountain pen
See more from jalbert
jalbert
Louisville, KY
This is a commissioned piece I finished up. It's very similar to a pen I previously made, but with some improvements. I made the pen completely from argentium silver, with an acrylic barrel/ink reservoir and cap liner.
I cast the argentium parts from wax tube and sheet, and formed the rough castings around aluminum mandrels I made, which went on the lathe for truing up and finishing. As always, when working with significant amounts of silver, weight and waste are the two factors I try and minimize. Wrapping wax sheet around my tapered mandrels allowed me to minimize both of these factors, as it gave me a casting that was an even thickness throughout, and tapered as needed for the final shape of the respective part.
The pen is approx 45-50 grams, which is reasonably lightweight for a metal pen. It fills via piston unit, which I fabricated as well. It is about 5" long when capped, 1/2" diameter at the cap threads, and uses triple lead 12tpi threads. The main improvement I incorporated in this pen from the prior was a multi-piece cap, consisting of the cap sleeve, acrylic liner, clip, and screw on finial. On the prior pen I simply had a cap sleeve With the clip soldered on, and an acrylic liner that was shellacked in place. This is a much better construction, as it does not use any adhesives as the means of connection. In fact, none of the parts on this pen rely on the use of adhesives, and contain threads or other mechanical connection for strength. I also incorporated a silver section/cap threads. To finish the pen out, I threaded it for a Pelikan M800 nib unit, which are expensive, but superb.
this took a considerable amount of work, 20-30 hours, and I am quite happy with the results. Important to me was nailing the engineering aspects, such as cap construction, which has been an ongoing experiment.
Lucky2
New Brunswick/ Canada
I like it, and I understand why it would have so many hours, in making it. I've done a fair amount of this type of work, and it can be tedious to say the least.
Len
jalbert
Louisville, KY
really nice pen I would love to know or learn how to cast parts for fountain Pens
There are a lot of good resources out there to learn from. I learned casting in college as part of my art program and then applied it to penmaking, but there are a lot of good articles, books, and videos out there.
Sripal
India
View attachment 253598View attachment 253599View attachment 253600View attachment 253601
Amazing output!!
Hell lot of work and impressive to know that you have hand made each element of the pen.
derekdd
Wisconsin
Wow. Love the creativity and craftsmanship.
I'd just like to hang out in your shop for a day and watch you work.
Kcimdrib
UK
A awesome looking Pen and worth every second you spent working on it .
