Recommendations On Refinishing Service
Treesaurus
USA
Hello All,
I have a nice wood pen that is in need of refinishing. Does anyone have a recommendation for someone who does refinishing work?
Could you take it back to the person you purchased it from ? It appears from the photo to have had only a wax finish , which of course wears off with use . You should have been apprised of that . If you want a permanent glossy finish , someone near you can probably do it with CA . If it were mine , I would leave it as is , a very nice looking pen .
The grooves in the wood make me shy away from this job, since CA almost always has to be sanded and polished. Consider wipe on poly?
Thanks! I should clarify that I am just looking for a glossy permanent finish. Doesn't need to be CA if it will not work. This is why I came to the experts.
A big thanks to mmayo for the refinishing. A true masterpiece that I will cherish.
