10 Minutes To Better Assembly - Another Video
mg_dreyer
Aurora, Ill, USA.
Another video - this time on assembly. I look at slimlines / sierra (wall street or diamond knurl) / pens with stylus tips / "jr's" two barrel line ups).
One of the tools I used (and attributed to this website) was from someone on this website. I could no longer find the write-up in the library. If you know who came up with the bolt and nut technique - please let me know. Would like to credit in the write-up. Attributed it in the video to the article.
Click Here To Be Taken To YouTube Video
That is the exact part I mentioned above. I do not take credit for it, but have been using it for 10 years. If anyone knows who posted it first - please let me know.
Thanks for watching. And you get a lot off this website....
Mark,
This video is great. I love the nut-and-bolt trick for assembling the slimlines. And I also think you solved a problem I'd been having with the tip to never press on threads. I'd been having issues where the body finial on my mistrals has not been lining up perfectly with the blank body. I wasn't sure what the issue was--I TBC so it couldn't have been an issue with a warped mandrel. I measured and the thickness of the body was spot-on for the diameter of the finial. And things were lining up perfectly on the section end. I has no idea what was going on because it would always feel like the finial was going on slightly shifted--it would overhang by a fraction of an amount on one side, and underhang by the same fraction on the opposite side.
Well, as many of you know, the mistral finial is two pieces. There's a piece that pushes into the tub and that contains threads on the other end. Then you drop the spring into there, and the actual finial screws on over the spring using the threads. I was putting pressure directly on the threads when I assembled the pen AND THEN screwing on the finial. I think that was my problem, and so far as I can tell one of two things was happening. I think the piece with the threads might have been going in on an ever so slight angle, or I was warping the threads in such a way that the finial was no longer perfectly centered after you screwed it on.
I've since started assembling the finial before pushing it in, so that the pressure is now on the end of the fitting and not on the threads, and they've been perfect every time! I also like the idea of using a spare tube or a nut to avoid putting pressure on the threads and I may try that.
This was super-helpful, Mark. Thank you for posting. And awesome car in your profile pic. '56, right, or is that a '57? I can't quite see enough of the back end to tell.
Mark,
Thanks for watching the video. I appreciate it.
As for the car it is a 57 Bel Air 2 door hardtop. Nothing but fun to drive it.
