Very Delicate Blank
DorenaGay
Richmond, TX
I am looking for recommendations for the best way to glue a very delicate pen blank. Is a two part epoxy better than CA? The bank is the Yankee Pinstripe blank from NV Woodwerks. It is a fusion of 3D printing and resin casting. Thanks!
mark james
IAP Collection, Curator
Medina, Ohio
I would recommend a 2 part epoxy, and let it cure overnight. Be careful that you are accurately marking the exact center of the pattern on the ends. If one of the ends is slightly off-center, you will have a taper in some of the pinstripes. The video that is linked to this blank on the website is very good.
Have FUN! and please show us the pen after it is turned.
I too highly recommend a two part epoxy to glue blank to tube. I do this with every pen I make. I am a big fan of SystemIII T88 epoxy. It has a long open time and needs to cure at least 24 hours. I am not familiar with the blanks you are talking about and if they are opaque or somewhat transparent. If not sure I will always at the very least tint the epoxy and this case white. Good luck and take your time and you should do fine.
