Sure Shot clogged
Bope
Western NY
I have a Sure Shot atomizer I use for accelerator. It has been working great until I used some E-Z bond accelerator. After sitting over night it appears that the valve is clogged. The nozzle may also be clogged but I can't get it to spray even without the nozzle. I am not sure what brand accelerator I had before but it never clogged. Any ideas on what I can use to dissolve the dried accelerator? Water didn't work.
Bope
Western NY
I did a little more investigation. The accelerator I had been using was Stick Fast from the spray bottle not aerosol. That is benzene based. The E-Z bond is acetone based. I will see if I can find a spray top for the bottle that is acetone resistant so I can use the E-Z bond. I will go back to the stick fast since I like the fine mist the sure shot.
Mortalis
Bardstown, Ky
Good luck with that. Acetone is nasty nasty stuff. There is a reason you can only buy in glass or metal.
TonyL
Georgia
I own the same. Call the company. They may have a solution or replace the part. I have called them and they were very helpful.
Monty
Group Buy Coordinator
Pearland, Texas, USA.
Which Sure Shot model do you have? Been using EZ Bond accelerator in my Sure Shot for years with no problem. When was the last time you replaced the internal spray parts?
Bope
Western NY
I have the B000CB it is the red can. I just checked it today and it is working again. I finished a pen and will check it again tomorrow to see if it is still working. If there is a rubber seal in there that swells with acetone that may be the culprit. If I continue to have problems I will give them a call. It is good to hear someone else has had good luck with EZ Bond in these sprayers. I was not looking forward to possibly using the spritzer bottles again. They give such a poor mist.
Bope
Western NY
It is not working again today. I think there is a seal in there that is not compatible with acetone. I will try calling and see if they have something that is compatible.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Hey Monty!
I have the repair kits for both the regular and the mild accelerator. Years ago, I got them and knew which was which--that was then, by now I don't remember the specifics. But, if you do remember, I have the parts available.
Monty
Hey Monty!
Ed,
Don't remember which valves and o-rings (vitron, BP, or butyl) work best with the acetone based accelerator. All I know is I've only had to change mine out a few times in the past 5 or 6 years and I used what I have and they are labeled butyl.
If the kits you have are labeled, give Milwaukee Sprayers a call and verify with them.
