Replacement Nibs for Higher End Jr Series.
TonyL
Georgia
I like the stock nibs (Dayacom) that come with the Jr Antony, Aaron, George, Cit zen series. Unfortunately, I irreparably damaged a few. If I want to try another brand compatible for the stock nibs what size/dimensions do I buy?
Thank you.
My understanding is Dayacom nibs are in fact JoWo nibs. The nibs used in kit fountain pens are #5 (smaller) and #6 (larger). I think some of the newer juniors use the larger nibs.
Do a good turn daily!
Don
I'll appreciate this thread as I am exploring this topic. Sorry I have no info to bring to the table.:redface:. I'll check the FP's I am playing with and try to add to the thread.
And yes, I suspect a "search" will reveal a lot of previous insight - I'll do that before asking.
Thanks for the plug, Bob!!
Yes, Heritance nibs were made to fit the jr. Gent series, about 5 years ago. Then, CSUSA changed vendors and their spec changed, the nib fit, but not well.
However, it had been fitting the Berea line (Baron, Sedona, Atrax, Triton). Now, it seems the Heritance nibs fall out of SOME of those. We have not changed the Heritance nib, we had to buy thousands and are still working off that supply. So, the nibs, feeds have changed.
We cannot control this, but we ARE working on a solution. Will let you know when there is a product to announce.
Sorry (you have no idea HOW SORRY, when we had thousands of nibs made to fit and now they don't!!). We won't make the same mistake again.
It IS possible the Heritance nibs will, once again, fit the Junior Gent now that Dayacom is making them, again. We have not yet tested this.
Last March at the Penturner's gathering in Augusta, GA I made my first "kitless" pen. I asked Jonathon Brooks to tune the nib, etc for me. He did. The pen has been on my desk since last March. I use it often but it sits for several days between the times I use it. The pen has never failed to write first time...every time. I am amazed but delighted. I have done nothing to the pen except change the ink cartridge.
A couple of weeks back I asked Jonathon for some info on what he did to tune the nib and he sent me links to a series of videos. Here is that list:
https://www.youtube.com/watch?v=uuq9tuKRbCY
https://www.youtube.com/watch?v=1YRnN99412o
https://www.youtube.com/watch?v=9gVxmrqwukI
I am watching and practicing on another pen and once I am confident with the process I plan to work on the other fountain pens I try to use.
Thanks again Jonathon (IAP user brooks803)
Don
Thanks folks....so it is Jowo number 5 or 6? Or does anyone know of another brand. I have half dozen nibs that don't fit anything (any kit makers pends). I was warned by the seller though.
Oh my... sounds like you need to start thinking about kitless Tony :D You can do it!!!
Thank you all very much.
Most, cautioning most not all, more common pen nibs are #5 or #6 , check out fountain pen revolution web site he imports a bunch of Indian nibs and ebonite feeds that are decent quality also the pens themselves are low enough cost have bought them for parts to make kitless pens
Just carefully remove nib from feed and housing and fit new one
But generally some tuning, taking a loupe and tweezers and adjust tines if out of alignment, then smoothing with some ultra high grit micro mesh pads but even stropping figure 8,s back of a legal pad or some leather can make a cheap nib perform nicely
Meaning even a high end nib if not tuned will perform terribly
Sent from my iPhone using Tapatalk
Hi Tony, Did you ever settle on some nibs that fit the JR II series? I've got a JR Gent II that I thought had a Jowo #5, but I put a Jowo #5 in there and it doesn't fit.
