A contrast in bowls
See more from Cwalker935
Cwalker935
Richmond, Va
Simple clean utilitarian cherry bowl vs. end grain turned cedar bowl
Cwalker935
Richmond, Va
Very eye catching. How did you keep the cedar end grain bowl from cracking, especially at the pith?
I dribbled thin CA into the cracks, kept my bowl gouge sharp, made light passes, and left it a little thicker than I would do on most woods. I tried doing a second one thinner and after taking it off the lathe it split in half when I was trying to do a little sanding on the bottom. I CAed it back together and had it 90% cleaned up and it cracked in a different place. Just wasn't meant to be.
mark james
IAP Collection, Curator
Medina, Ohio
I'm glad you didn't hint for a choice between the two. Each is beautiful. The Cherry is more clean and neat, but the colors of the cedar is amazing. So kudos for both!
Very nice Cody.
