TCP Global Pressure pot
Dieseldoc
Livermore, Ca 94550
Does anyone have any experience with these pressure pots?
5 Gal Air Agitated Paint Tank 20 Liter Pressure Pot W-Handle
Says they are rated to90 #. They come in various sizes. Not bad prices.
I have a TCP 2.5 gal 10 liter pot and it works great. Very easy to modify for casting, just put out mixing assembly and I taped the hole with 3/8 pipe tap, installed brass plug with Teflon tape. Removed all of the fittings in the top and cleaned up the threads in top and fittings, used Teflon tape and reinstalled. Reason I resealed fitting there were some that leaked a little. My pot will hold 90 PSI for 24 hours.
jcjc
PDX, OR
i have what I'm guessing is the same pot from Home Depot made by California Air Tools. The only difference that I can see is that the Home Depot version has a manual agitator. Mine works great and holds pressure no problem. Cost is 250.
