Aces-High
Very beautiful, in the extreme !!!
What thickness are the veneer pieces ?
Thanks, Jason. They do look thinner when comparing to the diameter of the pen.
Near the middle of the pen, I see 4 parallel and horizontal veneer pieces (two green, two white), so they would make up 4 x 1/8" = 1/2", and then there are the top and bottom pieces which would each be thicker than 3/8" each, so the pen would seem to be 1 1/4" total diameter. I am quite sure that is not the case so I must have misled you with my question.
Maybe when I said "veneer pieces" you thought I meant the undyed reddish-brown pieces at an angle to the pen axis ?
