Thanks for the quick replies. Can I reapply CA from here, or should I sand it all off and start fresh?
Sent from my SM-G955U using Tapatalk
Tell us more about your application process. How many coats of what thickness CA. What did you sand the CA with before micromesh.
Try this https://youtu.be/eL9T-H8Hfv8
That video was very helpful, thanks!Thanks for the quick replies. Can I reapply CA from here, or should I sand it all off and start fresh?
Thanks!
Thanks for the help all! I tried applying more ca before I sanded it bare and out came out pretty well. There is a little discoloration that can be seen on the bottom of the blank in the second picture. Not happy about it but I can live with it for the learning experience. You all were fast and a ton of help!View attachment 172157View attachment 172158
That is a "feature" you won't find on most of my competitors lower quality pens. $5 more for that pen!"splotchy"
There are probably better responses coming, but for me it wasn't much of an issue. I do thin coats of ca, and stopped every now and then to pop the bushings loose as I layered on the CA.Bit of a noob question here. How do you keep the CA from gluing the blank to the bushings?
Thanks! I just ordered a set.Bit of a noob question here. How do you keep the CA from gluing the blank to the bushings?
Hi pshrynk, I use these:
https://www.woodcraft.com/products/...MI3vfo9fuv2QIVApF-Ch01HgPTEAQYASABEgKSqPD_BwE
As soon as I'm done shaping the blanks to the bushings, I take the bushings off and use these things for sanding, staining, and finishing. They work great
While we're on the subject, my problem with CA lately is that somewhere between a week to a year after finishing, my pens have been developing checking--a million little hairline cracks. Does anyone know what causes this? It's frustrating, because it doesn't happen all the time. Is CA vulnerable to temperature or humidity?
Thanks for any help.
Do you use calipers to measure your turnings, and then the thickness of the amount of CA build up? Many people use calipers, turn the blank down to something like .007 to .01 below the bushings (actually turn to those numbers below the size of the nib end, CB and Clip end.)
1. Build up a thicker coat.
2. Lately I have been reading that some who use StickFast CA have had more cracking than with other CAs.
3. Humidity and Temp, - it does affect it but it is more or less if the blanks are not dried enough or stabilized before turning and finishing. Cross Cut blanks without drying and stabilizing will crack the CA on many/most woods.
Meanwhile, the High Build Friction Polish from Dr.'s Woodshop has been working really well. I put it on at high speed and the shine is about equal to the CA. I've heard that it's not as durable, though, I'm going to use a couple of the pens for a while to find out. Anyone else have experience with this product? It's a different formula than the Pens Plus.
I don't worry about it. When it's all done, an upright tap of the bushing on the lathe bed will free them. Any tiny jagged overhanging CA gets sanded off.
