BeeAMaker
I'm experimenting with using dyes in CJ to create multicolored blanks. Like this one I did a few months ago.
The one pictured I simply placed the blank into yellow dyed CJ and let is soak up the yellow CJ, then placed it in Purple dyed CJ and placed it under VAC for 24 hours.
Surprisingly it didn't VAC all the yellow dye out and replace it with Purple, and it didn't seem to mix. What I am wondering is if I just got lucky, or can I expect this result each time?
Should I soak it in one color first, then cure it before VAC in another color to ensure they don't mix? Is there info some place on doing multicolored CJ blanks? How would you go about doing this?
