yarn bowl
See more from triw51
triw51
407 East Cottonwood Drive, Cottonwood AZ
A lady asked me if I made yarn bowls I wasn't sure what one was. So she showed me some pictures and I told her I would try. I had been given a large maple log by a friend so wanted to try turning some of that. I has some splating and been attracted by the ambrosia beetle.
This was the first bowl like this I had turned I left the walls thick because I watched a video which said you want the bowl heavy so it stays put while the yarn is pulled through the hold.
My biggest problem was tear out under the rim and then cutting the slot to the hole. sanding the slot and hole was time consuming but worth the effort. The lady bought it the same day I finished it.
Finish is Doctor's Woodshop Walnut Finishing Oil.
C & C welcome
Very well done, William !!! . That piece of wood seems perfectly matched to its new role in life.
I am also intrigued by the background of picture #2 where there appears to be a piece of electronic equipment ... perhaps a signal generator ? ... with origins in Canada ... something I might have also encountered in my younger days dabbling in amateur radio.
Please tell me a little about it if you don't mind.
Mal as Pete pointed out I have an one way lathe. I was blessed a while ago with a used one way at a very reasonable price. I really like having a nice well built lathe
I'd save the pewter for where you can see it, so I'd use lead/steel shot in epoxy. You having some nice blacksmithing ability could make a Damascus ring to put around the outside foot of the bowl for something totally unique. ;)
Or the indent could be on the inside of the bowl where the pewter could be seen. Maybe with an imprint or pattern?
