Help - questions about drilling bench drill shift
zuocheng
Pen table drill hole, with a special clamping tool fixed, draw the concentric line after the vertical drilling, the speed of 1500, the pressure is not fast, but after playing the hole before and after the hole are not the same (Figure)
** Trouble you help me to see me in the end is the problem in that? Is the gripping tool offset or the table does not cause a smooth dip or other problems, how to solve!thank!
For drilling after correct alignment try DeWalt Extreme 2 drills they do not wander.
Use a straight rod in the drill chuck then square the table of the drill press first.
Have success Peter.
