eduardomachado
How will you make this?
Sent from my iPhone using Tapatalk
How many toddlers will that plate serve up?
Yup -- I had a porter cable router with a follower insert that fastened into the base and used a bull nose bit to cut around the edge (radius edge at the bottom and than used a straight 1/2 inch bit to hog out the center. The very center of the big compartment was a bit tricky keeping the router balanced but made a template for just the center and it worked well.
I turned the plate and put a large foot on it.
