Pen blank issue
Bernski69
What should I do ? Is this garbage or it can be fix?
Please help! Much appreciated !
Thank you !
Bernie
It can be salvaged. I'd first turn what isn't messed up round. Then I'd use a parting tool and turn . . oh. . . maybe 3/8" or something from the messed up end down to the brass tube. Then I'd root around in my bag of offcuts for an offcut in a complementary or contrasting color, drill a hole in it, and glue it to the tube and mating face.
I'd probably do the same on the other end, to keep symmetry.
"oops bands" are learning opportunities. You can pretend you meant to do that. Welcome to segmenting. :wink:
Thank you Brian
Much appreciated ! I'll give it a go !
Thank you !
Bernie
Oh my yes!
Do exactly what Brian said - maybe add section from old credit cards. Just make sure you have a nice tight joint between the sections.
Have FUN!
That is awesome! Thank you for your picture !
I'll give it a go!
Oh my yes!
Have FUN!
I've turned a fair number of pens and screwed up more than my fair share and I can't tell you how badly I wish I had read that or gotten that advice back when I started. :)
As my grandfather would say.... "It is only a mistake if you can't fix it."
Or in this case, make it look like that is what you wanted to do.
I look forward to see the results.
