Hot out of the forge
See more from Artisan iron designs
Maryland
Here is one of the pens I finished this week. The artdeco, thank goodness the tubes are so large, this allowed me to remove a lot of the weight otherwise it would weigh a ton. I had to start with a 7/8" Damascus billet. Hope you like it ...I do.
Very nice! I like it. Just wondering, is it possible to make a convex shape (bulge) on the metal lathe or just flat?
It's possible to make a convex shape, but it isn't easy. One can do it with files and or sanding. Or, you can modify the lathe to trace a pattern that will allow cutting curved surfaces. The items below were cut on a manual metal lathe using a tracing modification in acrylic and aluminum.
Another BEAUTIFUL Damascus pen Vincent!
Magnificent Pen Vincent.
Glorious Blank, Superbly Turned Fitted and Spectacularly Finished.
Beautifully Complimented with the Art Deco Hardware.
Outstanding Craftsmanship.
Brian.
