Ringmaster Lathe 724 Variable with accessories
dansills
Newberry FL 32669
Extremely light use - has only cut the rings for 5 bowls. All accessories included. Local pickup as shipping is going to very expensive. You get:
724 Variable speed Ringmaster Lathe - serial# 11855
PAG - Precision Angle Guide with DVD instruction
Ringmaster blade cutter pre-set gauge - for aligning blades
Lathe spindle Adapter 1"x 8 tpi- for mounting bowls on wood lathe for sanding
Ringmaster Glue Clamp
1/2" plug cutter
Ringmaster Steady Rest
Protoshaper excel program for shaped ringmaster bowls
Everything you need to make bowls from boards - $400 for everything
1/2" plug cutter
I have 1st dibs on this from his original post. I hope he will honor my request on his original post. I will pay for shipping
1/2" plug cutter
Absolutely you're first - Can you help with a shipping solution? The greyhound idea is intriguing. I'm calling Fastenall in the morning
1/2" plug cutter
How about shipping wars. I have used them in the past. I find them on the internet. Thank you for honoring my first request
Terry
1/2" plug cutter
Terry
Shipping Wars - I'll have to check it out.
1/2" plug cutter
Terry
What does the unit weigh?
Terry
PM Sent ...
Ringmaster is pending pickup
What the heck!!! Here I was willing to purchase the unit and shipping.. I'm not very pleased...
What changed ???
:confused: - I understand you were willing to pay for shipping but I was pretty clear that I wasn't willing to ship it and was looking for someone to pick it up. I priced it as low as I did only because I didn't want to ship it. A fellow member reached out and offered to pick it up. So, I agreed to mark it pending pickup.
PM Sent ...
What changed ???
It would have nice if I was made aware of the "pm". I'm going to be down that way in July. Oh well, I'm going to purchase a new one
PM Sent ...
What changed ???
Understandable. You're going to love it.
PM Sent ...
What changed ???
All is good on this end...Is there any attachments I should purchase from the get go
I was wondering if they were still in business.
No activity on their Facebook in a year or updates to their website.
You will really want a PAG, the mag cutter installation tool, digital calipers, the cheat sheet for setting angles, bandsaw, really good table saw, planer and or drum sander and a way to sand the finished product. There is a site I would recommend becoming a member of. It is ran by a gentleman that visits here from time to time. Woodworking Friends by William Young. He has the cheat sheet on the site you can just download for free. That is unless you are really good with trigonometry. Of-course lots and lots of wood. I would start off with cheap Popular till you get used to the machine and the quirks. I use the Guinevere system for sanding. This machine is all about sanding so if you don't like sanding by hand I would look into the power sanders with a flexible shaft. I have the variable speed model and don't recommend it the only thing I used that was to turn fast and sand slow. I didn't have a lathe at that time is the only reason i took that option. I don't think the latest version is worth it either as it only lets you make a on inch larger bowl. 10" or 11" bowls don't sell all that good unless it is a salad set. The most popular size for me is the 8". You should probably go to the site I mentioned and lurk around before buying on. It is a great machine and I paid it off on my first show! I usually turn $3000.00 a year on a hobby level and that is doing 5 shows a year.
Yes they are still in business and going strong.
