aggie182
I am starting to get things together. I'll update this thread as things come in and as I get them set up. Pics to follow shortly.
From the pictures, it looks like you went with the wolverine sharpening jig (or similar) and 8 inch grinder. I have the same setup and only needed a piece of 3/4" plywood to elevate the grinder. Construction lumber would put it too high I think. Also make sure you have enough room behind the grinder for the movable arm with the tilting platform to get close enough to the grinding wheel. I ended up putting mine on a small cart next to the lathe with drawers underneath for other supplies.
Don't be afraid to move things around. Most people's work space looks nothing like how they initially set things up.
Sure wish it came assembled!!
Sent from my iPhone using Tapatalk
Honestly....it is! :biggrin: Nothing in that picture other than the tool rest is technically required to be on the lathe to make it work.
Welcome and good luck. Watch a ton of YouTube videos.
Hehe, guaranteed it wasn't when he got. That's the same one I have and you have to put it together from the bed up.
That's weird. Mine came completely assembled from them.
